Adding a control panel
Jan 10, 2023
32
535
I am fairly new to caravaning but my old caravan had panel with switches for battery mains elec etc. My van only has a mains master breaker at the moment and I wanted to add this type inside the van is this straight forward. To do
Nov 30, 2022
1,984
1,881
2,935
Really?? That does seem very Unusual indeed.
Is this a touring caravan, which I would expect to have a control panel as it uses 230 and 12 volt systems, or a static which will only have a 230 volt system so will have no requirement for a panel to control the 12v.?
Reactions: Jamesl63
Jan 10, 2023
32
535
Mr plodd this is what I have at the moment in the van
Nov 30, 2022
1,984
1,881
2,935
So what is it, a touring caravan or a static ?.?
Its a simple enough question that needs answering Before we can offer any sort of advice.
Reactions: Jamesl63
Nov 30, 2022
1,984
1,881
2,935
First question, have you tried asking the previous owner/dealer it was ourchased from?
Second question does this caravan have a leisure battery anywhere? (It will look like a cars starter battery. It could be in an external locker or under the floor)
Third question does anything (such as lights, water pump or radio) work if the caravan is not connected to EHU
Like I said earlier there will only be a control panel if this caravan has a 12 volt as well as 230 volt circuits. I am beginning to suspect that it only has 230 volts and that is why there is no control panel. The lack of an awning light over the habitation door points to there not being a 12 v system.
Reactions: Jamesl63 and Tobes
Jul 23, 2021
1,084
1,025
5,435
The few I can see have been advertised with leisure batteries and/or motor movers, so it looks like as a brand they had 12V systems. James, can you say any more about the model? Keep looking. If you have a leisure battery installed, then there is a control panel somewhere.
Reactions: Jamesl63
4,374
The pictures you have shown us of your caravan only shows an ABB DS951-A protection device. This is a Ground Fault detector for the mains 230V ac supply and suggests the caravan is not built/converted to a full UK standard.
Many continental caravans do not have an onboard battery system, and rely just on the mains power, in which case the Sargent switch panel you has suggested you want would not be suitable as it is designed for 12V systems only and not mains power.
It is possible to put in a 12V system, but the Mains wiring should also be brought into line with UK standards, and the fact you have had to ask does suggest you don't fully understand the wiring in your caravan. I suggest you contact an Approved Workshop Scheme engineer to view the caravan and advise with the benefit of being able to view the situation first hand.
Remember that even 12Vdc electrical fitting if done incorrectly is still dangerous.
Jan 10, 2023
32
535
Sorry for any confusion as new to caravaning
Attached is the part of the manual for electrics
I have a battery under the bed with a transformer next to it
The caravan was bought second hand a Crystal moora 530 with a fixed bed 2005 I think they were from Belgium but sold in this country but no longer sold it has the usually kit cooker heating via a Truma unit AC unit alarm fridge
The unit can run off the battery under the bed as well as electric cable
4,374
With the new information, it does seem the Sargent switch panel could be fitted, but the exact details does require a proper survey of the caravan to plan the best and safe solution.
I'm still of the opinion your quest will best satisfied with an AWS technician who will know how to ensure all the necessary wiring is safe to use, and if it does go wrong you do have warranty for any work done.
Nov 30, 2022
1,984
1,881
2,935
Well it would appear that the manufacturer deemed a 12v control panel unecessary, which does seem odd but that's the situation you have. So why do you feel its necessary to have one?
3,663
According to the manual image, there's no provision for a 12v leisure battery, just 12v from a mains transformer with EHU and using the car battery when off-EHU.
Reactions: Tobes
