Adhesive on window
Apr 20, 2009
5,621
1,025
Just remembered that we have adhesive on the middle front window on the inside, obviously the last owners use to stick something there regulary as there is quite a bit.
The windows are tinted.
What is the best cleaner without scracthing the window?
Thanks for any suggestions.
2,054
As a start I would try a soft cloth wrung out in hot water held onto the patch to see if the heat will melt the glue. A steam cleaner and soft cloth might also do it. Not sure what the melting point of plastic windows is but I suspect it is higher than the temperature of steam.
mel
936
As unusual as it is for me to recommend WD40, but in this case it works !!
Put some on a cloth and gently soak the glue, it will soften and be easily removed, BUT, after, wash the area well wit a soapy water to remove all traces of the WD40
Apr 20, 2009
5,621
1,025
forest gump said:
meths it will clean the windows and a good drink afteer to toast the job.
I like the taste but not the smell
Apr 20, 2009
5,621
1,025
All done, nice and clean, could'nt find my WD40 so went with the meths, sparkling.
Thanks folks.
