Advice needed
Aug 17, 2019
117
18
10,585
Any advice would be helpfull my question is . I have a victron solar charger chargeing my lithium 105 amp battery we always camp off grid rallying with our DA . I have fitted a second battery a lead acid under the seat to power only the 12v tv for watching tv on a evening i was thinking is it possible to connect the second battery to the load on the regulator and charge the second battery instead of takeing it our to charge in the house there would be an inline fuse too the second battery for safety reasons if its possible to do thankyou in advance
Apr 23, 2024
271
211
935
the difference is minimal so the lead acid battery may be slightly overcharged if its not loaded but as you are off grid a lot and using power then it wont arise as the solar regulator won't deliver max voltage to the system , I would fit an isolator switch so that when out and about just let it charge up the lithium battery
Reactions: macafam
Jul 15, 2008
3,832
973
Any advice would be helpfull my question is : I have fitted a second battery a lead acid under the seat......
.........bare in mind a lead acid battery can give off explosive Hydrogen gas when being charged.
