Advice needed
Aug 17, 2019
118
18
10,585
Any advice would be helpfull my question is . I have a victron solar charger chargeing my lithium 105 amp battery we always camp off grid rallying with our DA . I have fitted a second battery a lead acid under the seat to power only the 12v tv for watching tv on a evening i was thinking is it possible to connect the second battery to the load on the regulator and charge the second battery instead of takeing it our to charge in the house there would be an inline fuse too the second battery for safety reasons if its possible to do thankyou in advance
Nov 30, 2022
2,021
1,930
Lead acid, and lithium batteries have different charging regimes I think, so I am not sure you can do what you propose
Reactions: ProfJohnL
Apr 23, 2024
671
536
1,135
the difference is minimal so the lead acid battery may be slightly overcharged if its not loaded but as you are off grid a lot and using power then it wont arise as the solar regulator won't deliver max voltage to the system , I would fit an isolator switch so that when out and about just let it charge up the lithium battery
Reactions: macafam
Jul 23, 2021
1,107
1,060
5,435
If you have sufficient solar to charge the lithium and lead acid battery, just do away with the lead acid. If you don't, then you want them separated so you don't run out of juice for essential services (as opposed to TV).
Given that a lead acid is perhaps 20kg, and a second solar panel more like 5kg, I would up my solar power to improved the energy collection for the lithium and stop carrying the lead acid.
Reactions: KiwiVanner
