We have the dealer fitted optional one on our Sterling Elite 2008 model, it's the Dometic B2200 with remote control, lights, and the heating elements too. It weighs in at around 34kg and uses about 4 amps max when cooling. It is fitted instead of the Omnivent and will fit any standard 400mm opening. We had the Omnivent transferred to the shower room in place of the mini Heki.
We have used it quite a bit this year as we were in France from September until recently, and also used it on our UK trip in April/May/June. If it is a sunny day a van will get quite hot even with the blinds all closed, so we leave it on minimum fan at about 22 degrees and find this keeps the van pleasantly cool for when we return after a day out.
On low fan it is reasonably quiet, but when the compressor starts up the noise increases and could annoy you if you are a light sleeper.
Fitting was done by our dealer, but is apparently fairly straightforward as there is a handy join in the roof lining to get access to run the wiring. The one problem we found is that the cover strips over the roof join prevent the easy removal of the filters for cleaning. To remove them we will have to remove the cover strips first and we are not sure how many times they will stand being removed and replaced. We have brought this little problem to Swift's attention and they have suggested we remove them just before our annual service and let our dealer replace them.
We also have a Mover fitted, and various other "extras", so we have now had our MTPLM uprated from 1815kg to 1900kg to keep our user payload intact. This has to be done via your dealer and will cost you about
