aks 2004 stabiliser hard to close
Jun 14, 2019
Hello everybody,
last year a problem with my AKS 2004 stabiliser appeared, after years of good service: it started needing a great force applied to it in order to close the stabiliser friction pads to the tow ball of the trailer hitch. When I say "a great force" I mean I literally have to jump over the handle with my full weight.
I've already tried replacing the friction pads with new ones, but the problem is still there, even if I did not fit any of the provided shim washers to the friction pads spindles.
What could be the cause of such problem then?
3,880
1,616
How easily does it move when not fitted onto the ball?
ie is there excessive friction in the cam mechanism that pushes the pads on?
I have always put a few spots of oil on these at each service and mine 11 years on remains free working.
1,818
They are stiff but should not be that bad but hopefully a bit of oil will cure it.
Jun 14, 2019
Very easily.
No, it doesn't seem so.
Thanks for the suggestion, I might try the same.
Jun 14, 2019
In the end it seems the culprit was a misplaced O-ring that should keep the friction pad in the correct place.
I removed the friction pads, disassembled the handle, noticed the misplaced O-ring, put the O-ring back into its correct place and now everything seems ok.
I'm leaving tomorrow for the holidays and let you know if my solution should turn out to be wrong, but I'm pretty confident it is ok now.
Sep 5, 2016
928
119
4,935
The rubber 'O" ring sits in a recess and before now when I have changed the side pads the 'O' came out with the pad and it was split in two, since then I have always had a few O rings spare,
Nov 17, 2005
127
22
18,585
Lucrus,
I had exactly the same problem with my hitch after the pads were replaced during the service and the O ring was not seated correctly.
