Oct 22, 2025
7
First post Please be gentle with me.
I have an Avondale Dart 2002 and I think that the suspension is a little low, as my ride height (Chassis just in front of the axle to ground) is around 7 inches as in the photo.
Also the wheel looks to be too high into the wheel well.
What are the thoughts of the masses.
2,681
Suspensions have been known to collapse. But it would be impossible to judge that from pictures alone. Technical evidence would be needed. Possibly Alko (if it is an Alko chassis). Might be able to provide the laden angle of the swing axle.
Hi looks like it's a common problem with the al-ko. Take a look at an alternative axle setup from guys in Exeter. Euro Axle would be a new, stronger, lighter axle setup and cheaper than having your setup refurbished. It's worth a look and a call to them. https://www.euroaxle.co.uk/products/axles/. info@euroaxle.co.uk
Oct 22, 2025
7
I have read that the torsion bars on a few caravans have snapped however this axle seams to be of the rubber kind(independent suspension style) I’ll try to get a photo of the rubber inserts this afternoon.
Oct 22, 2025
7
9,124
I had a 2013 Alko suspension go on one side in 2017. Looking underneath I could see that a part of the rubber suspension bush had extruded. What do your bushes look like? Mind you yours is considerably older and you don’t know it’s history. Alko no longer refurbish axles, mine cost me £1300 for a new axle and fitting. There is Fraser Brown in Scotland who refurbishes Alko axles but you have to ship it to them. They have been in business for years.
Oct 22, 2025
Hi, alloy axle's dont corrode as do traditional ones, lighter, stronger, cheaper from Euro Axle near Exeter. https://www.euroaxle.co.uk
Apr 23, 2024
501
410
1,135
Interesting info on the euro axles, Aluminium alloy does corrode particularly if connected to steel components unless coated or anodised, Alko trailers are full galvanised to stop corrosion. To check the axle look at the first image . The axle should be in position 1B when stationary. Also there should be about 25mm clearance above the wheel to the wheel box. Another giveaway is the brake cable touching the top of the hole in the chassis - see second photo. Make sure you haven't overloaded the caravan , get it weighed at a public weighbridge and check its MRO and MTPLM weights.
Oct 22, 2025
7
I'm pretty sure that you can see the ends of the rubber inserts I'll look when I'm back home.
The van tows great straight as an arrow up to 60, we were in the south of France in June, it just that it dragged its rear end lightly in the site we were on at the weekend , it was a bit rough! Other than that it's good. The motor mover has only 4 3/4 of an inch clearance
Apr 23, 2024
501
410
1,135
You will, most axle s have some rubber sticking out .The other issue is that someone may have in past fitted bigger tyres to the rims , check the manual to see what tyres it should have . there are quite a few different models of your van , 4/6 berth so you will need the full model number.
Reactions: FosterS
Oct 22, 2025
7
Thanks for that info.
I've had it on a weighbridge that's why all the heavy stuff gets put in the car.
I'll check the info out later today, I hope.
4,344
You will need to check who manufactured the chassis, but my suspicion is its an Alko based on parts of your description. Bearing in mind the caravan is 23 years old, and its using rubber suspension, I would expect some loss of strength, but whether its gone too far is very difficult to judge from pictures.
You need a competent opinion about the state of wear, and you will only be able to get that from a caravan repair specialist or chassis manufacturers agent.
I am not aware of any solution other than replacement of the swinging arm assembly to restore the lost height, and as "otherclive" has experienced that can be anything other than straight forward.
7
Thanks to everyone for the input not to much more than was in my head to start with but nice to have it confirmed. Probably going down the rebuild route but we will see.
Thanks again
3,904
1,089
.......I have always jacked my caravans to remove the weight from wheels and suspension when not in use for any length of time. The ride height is always noticeably greater when I remove the jacks after storing.
This may be something you could try first at very little or no cost.
Surely a new axle and it's fitting cost is not justified on a 23 year old caravan.
3,600
Somewhere in the documentation I received with my original '83 caravan there was a specific recommendation from Alko that the suspension should be "rested" during any extended periods of inactivity so that caravan and it's '01 replacement had wheels removed with axle plates resting on wooden blocks every winter - like yours it always rode slightly higher each spring.
Old age means that I've never bothered to do that with our present '13 caravan and it is showing signs of sagging - perhaps I should get someone in to do the job.
3,904
1,089
...I admit my caravans have always been stored at home and I have an air compressor and air jack to ease the process now!
3,600
I had, still have, an exhaust-driven air bag lift which worked fine on our original caravan but the replacements seem to have too many under-floor obstructions to put it in position
Oct 22, 2025
7
As the van is parked on my drive for the winter I will give that a try.
Reactions: Gafferbill
2,681
I have always put the chassis on stands for the winter. I just see it as common sense. Better for the suspension, the tyres and security. Now we are on a seasonal pitch, it was a no brainer. Surprisingly, many of my neighbours had not considered doing it.
9,124
Some early vans I lifted up over winter, but when we bought a new Bailey S5 it was so comfortable that we tended to use it right through to new year, and started again in March so putting it up wasn’t really worth the effort just for a couple of months.
Reactions: Jcloughie
