Swift Elegance 565, near side radiators are ok, offside ones are cool/cold.
Do they require some sort of balancing like some house radiators?
If so, how?
If so, how?
It sounds as if the ALDE system needs bleeding. With our caravan we have a radiator in the rear of the caravan. I heat up the heating, lower the front as much as possible and open the bleed screw on top of the radiator. Leave for about 30 minutes and then repeat. Also make sure that the pump is set to between 2- 3. Pump is normally next to the boiler.Swift Elegance 565, near side radiators are ok, offside ones are cool/cold.
If so, how?
Thanks for that. Any idea where the boiler actually is? I can’t find anything online or in the handbook.It sounds as if the ALDE system needs bleeding. With our caravan we have a radiator in the rear of the caravan. I heat up the heating, lower the front as much as possible and open the bleed screw on top of the radiator. Leave for about 30 minutes and then repeat. Also make sure that the pump is set to between 2- 3. Pump is normally next to the boiler.
