Alko ATC Green Light Flashing or on Permantely
Hi Everyone, i have just changed my 7n and 7s to new 13 pin plug to match my towcar, before i changed i used the 2 plugs connected to 13 pin method but didn't like that setup so i decided to use 13 pin plug with double grommet from ebay which is great.
However when i used the old method my ATC light stayed green when connected, now when car is connected i can still hear the werring sound but the green light now flashes, according to the handbook the green light will either stay green or flash to say the ATC is working has anyone else had this happen or doe's your ATC flash green to show working
Thanks in advance just need to ease my mind.
Hi
According to the book you should drive forward so that the atc can detect movement and then look again, however what it dosent say is what to do if its still flashing.
Dave
You will probably find the voltage is a little low. I've had it happen a couple of times but after a few minutes running the engine it goes to steady green. It's perfectly ok to use with the green led flashing.
