- Mar 14, 2005
- 7,510
- 936
- 30,935
Quote " This cabling is near to the main gas line from the from the front locker, where there is a cut-out for the gas line to pass through, which is easily large enough to feed the 2 pin connector through into the front locker, where it be safely tie-wrapped to the line out of the way of being snagged, and away from the elements."
The big problem with this "tip" is that you are NOT allowed to have the cable in the gas locker and most certainly NOT attached to the gas pipework !!!!!!!!!!!
