Recently fitted a used Alko hitch 2004/3004 to my Sterling Excel but have noticed that the red handle is riding up of its own accord after I start towing, is this a sign that i need to replace the friction pads?
PaulJ_374574379 said:Recently fitted a used Alko hitch 2004/3004 to my Sterling Excel but have noticed that the red handle is riding up of its own accord after I start towing, is this a sign that i need to replace the friction pads?
PaulJ_374574379 said:"No. When you hitch up and push the red lever down a small 'button' should rise and you will be able to see a green band. If the button does not rise and/or you cannot see the green band then your pads needs replacing.
Read more at http://www.practicalcaravan.com/forum/technical/49565-alko-hitch#ipTEuR7iLlOFLv1v.99"
Surely the green button rises with the application of the Black handle? and failure of the green button to appear will not surely indicate worn friction pads?
Highlander09 said:I had the lever ride up, I needed to change the tow ball as I was advised that it did not have enough "neck" for the ALKO stabiliser. No problems after the change. The new tow ball cost about £10.[/quote
£10???
A bargain .
I' very just paid £30 for a genuine Al-ko towbar complete with nuts and bolts.
Dustydog said:PaulJ_374574379 said:"No. When you hitch up and push the red lever down a small 'button' should rise and you will be able to see a green band. If the button does not rise and/or you cannot see the green band then your pads needs replacing.
WARNING
The Green pop up button will only be operational by the use of the black Al-ko hitch lever. The button's sole purpose is to indicate the hitch is safely attached to the towbar. It has nothing to do with pad wear.
Also as a precaution it is good practice to wind the jockey wheel down to just lift the tow car confirming safe hitch up.
Can the OP advise how much pressure does he have to apply to lower the red stabiliser lever.
Woody3 said:PaulJ_374574379 said:Recently fitted a used Alko hitch 2004/3004 to my Sterling Excel but have noticed that the red handle is riding up of its own accord after I start towing, is this a sign that i need to replace the friction pads?
Woody3 said:I stand corrected - but as ever this was what I was told by the dealer and I have never had cause to RTFM!
This may help:-
http://www.al-ko.co.uk/edit/files/handbooks/aks-3004-handbook.pdf
This may help:-
ProfJohnL said:RTFM = Read the Manual, but some people tend to add unnecessary expletives in their vocabulary.
Dustydog said:ProfJohnL said:RTFM = Read the Manual, but some people tend to add unnecessary expletives in their vocabulary.
I must be losing it.
Isn't it Refer To Fleetwood Manual? 😉
