The new caravan I have just bought has the spare wheel mounted on an Alko carrier just behind the axle - ideal for the weight but not so good for access.
Not having had such a fitting before I decided to investigate the practicalities of changing a wheel such that I could do so in the warm and dry weather away from traffic rather than on a wet cold European motorway one December night.
The wheel is secured to the carrier by a central centralising fastening and also by a bolt which comes up through one of the holes in the steel wheel and is secured with a locknut. This seems considerable over- engineering and is quite difficult to remove when the carrier is pulled out from the support holes and lowered to the ground. The wheel will not come out directly towards you as the ground clearance under the chassis is insufficient even when the front of the caravan is lowered as far as possible to increase the ground clearance under the rear.
The wheel then has to be lifted sideways over the two bolts projecting upwards from the carrier plat. This is extremely difficult for someone less than 100% fit lying on the ground
Putting the wheel back into position is equally difficult and engaging the cenrtal retaining device by feel can take an unreasonable amount of time as the end of the central bolt is uneven.
Although the engineering appears obvious, i found the whole process so difficult that I am wondering if i am doing something completely wrong - but I don't see what.
Advice from the experienced please - failing which i think my nex ploy will be to take out the retaining clips on the off side and drop the entire carrier onto the road before dragging it out and dismantling.
