Hello Kevin,
One of the ways manufacturers have been improving economy has been by keeping the cars Cd values as low as possible, and this has been aided by CAD modelling and some dedicated air flow modelling packages, so I suspect there isn't a lot that can be done for solo cars by adding after market aerodynamic products.
But as soon as you attach a caravan, the aerodynamic package changes considerably, and for the worse. Obviously there is the additional mass of the caravan, passengers and luggage, which has a very obvious effect on the ability of the engine to haul the outfit from stand still, but in addition is the physical size of the caravan's body, which has more resemblance to a brick than arrow, and that has an increasing effect as the speed builds up.
Where as most family cars that are capable of towing an average caravan are mechanically able to reach 100MPH or more and their aerodynamics and mechanical components should be rated accordingly, they are of course limited to 70 MPH in the UK and when towing they are further restricted to a maximum speed of 60MPH on de-restricted dual carriageways and motorways. So the higher speed aerodynamics of the tow vehicle may not be explored when towing.
Caravan manufacturers are not unaware of the aerodynamic effects of their products which is why since the 1980's most new products have gone away from the vertical slab fronted designs and now include some more front rake angle, and detailing of the rear panels, usually created by moulded panels.
The problem is neither the car manufacture or the caravan manufacturer knows whose product their own will be paired with by the caravanner. Consequently any particular feature either manufacture creates for their own car or caravan may be negated by the design of the other manufacturers product.
However clean the air flow is over a solo car, as soon as a trailer or a caravan is coupled the recombining airflow off the car is presented with a new obstruction of significant size and effect. What this means in detail will be different for every possible combination of car and caravan.
There have been after market aero packs for caravanners which basically consist of an angled board or scoop designed to be fitted to the roof of the towing car. The marketing gave the impression these are designed to interrupt the airflow passing over the roof of the car and to deflect it upwards in the belief it will then be high enough to pass cleanly over the towed caravan.
It is questionable if these devices do provide the suggested improvements they claim. What I am convinced is they would need to be placed and tuned very carefully, and if miss placed are likely to make matters worse, and as there are no detailed instructions on how to check the position of them, its down to trial and error, and the differences will so easily be swamped by other factors which will easily mask small incremental improvements.
I do hope your research will prove fruitful, but do make sure the methods and results stand up to fine scrutiny.
