Another lights problem
It was recently brought to our attention that the reversing light on the caravan (Abbey, 3 years old) wasn't working. Further investigation revealed that the 10 amp fuse on the car had blown. I tried another and that blew. I tried a 15 amp and that blew. I then tried a 20, which did not blow but only just illuminated the car's reversing lights (pathetic glimmer) and the caravan not at all. Any ideas?
Homer
Homer,
Just one comment - dont keep incrasing fuse amps. The designers have made a design fuse for a purpose, and if there is a partial short, and you keep upraating the fuses, it WILL cause a fire.
If that happens - maybe a replacement loom. Now thats lots of dosh !!!!!!!
Find the fault - cure it - and use oonly the correct amps fuse.
Good luck
