Parksy said:Hi Anseo
With a bit of research you should be able to obtain the components for a good solar set up for around £200.
A typical 150 watt 12 volt solar panel with mounting brackets which bond to the caravan roof is around £120
[*]you'd need a MPPT solar regulator to avoid frying your leisure battery, around £35 should do it
[*]A waterproof cable entry shrouded gland will get your cables from the outside to the inside
We're up to around £165 worth of haggis bonds now, but you also need suitable automotive flex and the bonding agent to roof mount your solar panel and entry gland, so around £200 or slightly over should get you there for a good solar set up that will do the job for you.
You might find less expensive components, I just had a very quick look and it pays to shop around.
I'm sure that forum members will be happy to offer advice on how to assemble and fit your solar set up, Click Here to see how I did mine.
The random example that I demonstrated isn't a kit and while I agree that the solar panel will have pre - fitted tails the automotive flex is the correct material to use to hard wire the system to the caravan as I did.I didn't use crocodile clips, the regulator is connected to the charging circuit using a plug in from Sargent. Solar panel mounting brackets of various kinds can be bought separately.chrisn7 said:There's plenty of choice on ebay - you should find a 100w kit for well under £200.
The kit you were looking at only had corner support brackets. Personally, I would select a kit that has 2 side supports as well i,e 6 in all , to stop the panel flexing in the centre, and provide more bonding area. A good kit will come with correct solar wiring as opposed to automotive wire, and proper solar connectors, not croc clips
chrisn7 said:... and correct solar cable has far more fine copper wire conductors than automotive cable, to minimise voltage drop.
chrisn7 said:Sorry Parksy but I will disagree with you on the wiring. A roof mounted panel may need a longish wiring run, and correct solar cable has far more fine copper wire conductors than automotive cable, to minimise voltage drop. This cable is the same as the tails that come pre fitted to the solar panel. You only have to look at the bared cable to see the obvious difference.
Of course the correct cable connectors should be used too for similar reasons - they have be soldered to the cable, are water proof and polarity protected. Forget any automotive plugs, cables, connectors for minimal resistance and reliability in the system
ProfJohnL said:Hello Anseo,
I suspect you may be over complicating the answer to your problem. Referring back to my quick calculation, I suspect you will more than enough capacity with a the 150W panel a simple controller, and a 110Ah battery.
A second battery is a another possibility, but then how do you charge it, and as has already been mentioned it adds weight and it must be secured and stowed properly in an acid proof container ventilated to the outside. It may seem a lot of work and expense for little reward.
Whats the worst that could happen? :huh: (perhaps i'm opening an can of worms here 😱hmy: but) you may have to curtail the television hours a bit. :blink: You may have to relearn the art of conversation over some liquid refreshment!" :cheer: Or discover the delights of arguing if "ix" is a allowed in Scrabble. :evil:
Peter_374304682 said:changing the van Next month and I'm told the new heating has no convection fire just blow heating so not sure how the main battery will get on then ?????? I'm getting a xplore 554
ProfJohnL said:I can't answer the question of how much current the heating will take, but I suspect the manufacturers are expecting most caravanners to be using sites with mains hook ups.
Anseo said:ProfJohnL said:I can't answer the question of how much current the heating will take, but I suspect the manufacturers are expecting most caravanners to be using sites with mains hook ups.
Guess I will need to get out there and find out Prof, I have a spare battery for back up so not too concerned about battery depletion.
And I will get round to purchasing the solar panel (I'm having second thoughts and considering a portable folding panel now :blink: ).
Anyone used gas and the blown air system off grid ? Even a rough estimate of current consumption would be helpful.
ProfJohnL said:The blown air system when on full blow will consume no more than 1.5A an often less when its turned down
Anseo said:ProfJohnL said:The blown air system when on full blow will consume no more than 1.5A an often less when its turned down
Prof, can you help me a little bit more please ?
Is that 1.5A per hour, or what ?
Thanks,
Anseo
