- Jun 20, 2005
- 20,051
- 5,311
- 50,935
Whoops just crossed with the Profs
I’ll correct later DD
Humidity is the amount of water vapour, an invisible gas, in the air. Warm air can ‘hold’ more water vapour than cold air; in fact, air at 35°C can hold six times more water vapour than air at 5°C. Probably the opposite to what most believe.
Mould is an airborne spore that thrives in a specific set of circumstances.Lack of ventilation is the primary cause rather than the ambient temperature. The dehumidifier doesn’t change the temperature.
More importantly I have found the best deterrent for Mould is wiping down all hard surfaces with a cloth that has been rinsed in a 10% bleach/ water solution. The spores don’t like the treated surface and won’t germinate.
Hope I haven’t spoilt your day Mel but I am not a fan of the dehumidifier as I don’t believe it achieves the results you seek
Just opening the door and then closing it will in most cases equalise the caravan humidity to the outsideOK clearly I am using faulty logic here; so here are my “workings out”. Which step is sending me in the wrong direction.
1. Using a dehumidifier immediately after using the van will remove the moisture generated by use ( breathing, showering etc). Thus the van now contains less moisture than before I used the dehumidifier.
Not quite. I doubt the internal moisture will exceed that in the ventilated ambient air.2. When the van is not used, over time the moisture inside increases due to airborne ambient moisture.
Unless you have water ingress, adequate ventilation will halt moisture build up.3. Even with some ventilation the moisture will increase over time as it is trapped in the van so that it rises above external ambient.
There seems to be some misconception regarding exactly what a dehumidifier does, and how moisture is related to humidity.4. Deployment of a dehumidifier for a fixed period will reduce the moisture content to below external ambient especially in a small 2 berth such as we have as the dehumidifier will remove moisture faster than it is getting in.
Steps2, 3 and 4 repeat over storage time.
Outcome: the moisture content of the van is managed to be at or below ambient for considerable portions of storage time.
Couple of caveats; our van is not on the driveway so cannot try this- it is a thought experiment ( Shrodinger’s dehumidifier 😀)
Also not read any peer reviewed papers that experimentally demonstrate results.
Thoughts?
