Aquaroll - some advice please
Jan 18, 2008
Please can someone tell me the most straight forward way to couple 2x40 litre aquaroll water containers in order to prolong the supply of water?
937
Paul, if you are using an external pump, then there is only one way, change the pump over when one roll is empty or nearly empty, then fill the drained one.
If you want permanent water supply, you will need a serviced pitch and a mains filling system to your aquaroll, usually a Torbeck valve fitted to the side water cap on the aquaroll.
3,659
Don't forget to double up your waste containers as you'll have 80m litres to get rid of.
Jan 1, 2006
412
Paul
I have seen two Aqua rolls linked by using a syphon tube simple and costs very little, look on E Bay.
Oct 4, 2007
11
paul,if you have a length of tube place one end in one of the full aquaroll suck out the air and push the other end of the tube in to the other full aquaroll (both containers at same level)it works perfectly done it many times
Sep 13, 2006
1,411
Ditto Tony
Our filler pipe end pulls off and this leaves an ideal syphon tube, I then push the end in next to the tube and pop the cap on top of it to help prevent any aerial deposits.
If you have trouble getting the syphoning technique right raise one of the rolls - or ask a scouser to do it.
