Why don't PCV do a review on whether a motor mover on a twin axle should be fitted in front of the axle or whether it should be fitted on the rear.
In front it may increase your noseweight as a twin axle motor mover weighs in the vicinity of 40 kgs and this is difficult ot overcome because if you start moving stuff to the rear you can end up with a tail wag. Also as the front of the towing vehicle is lifted it may cause problems when overtaking trucks. At the rear it may reduce your noseweight too much but this can be overcome easier than the opposite way around.
At present all we have in the front is the gas bottles, 2 x empty aquarolls and the empty waste water drum and my noseweight on my Lunar is quite a bit over the top. Not sure if the 110 amp battery weight comes into effect as it is vitually right in front of the front wheels of the van.
Surely manufacturers should realise that there is a possibility of motor movers and larger batteries been fitted to bigger vans thus having a considerable impact on their weight distribution? Can PCV take this up or do PCV prefer to take neutral stance and not do an investigative journalism in case they offend one of their advertisers?
 Facebook
Facebook Twitter
Twitter
