- Mar 14, 2005
- 18,661
- 3,920
- 50,935
There are many questions posted about nose weight, and clearly it is a subject that is not fully understood, and that is partly because it is a quite complex factor to measure accurately.
I believe I can suggest a simplified approach that whilst it will lack the ultimate accuracy, it will always provide a result that is at or just below the real figure.
If a nose load gauge (either a propriety product or a bathroom scale with stick) is set to give a tow-hitch height above the horizontal of 350mm to the centre of the ball, then any measured nose load will be at or just below the real figure for any EU compliant tow car and tow-ball.
Through the regulations, it is essential that a trailer (including caravans) must have vertical nose load that presses down on the tow vehicle, this can only be achieved if the caravan's centre of gravity is forward of the main axle. Given these conditions, and the fact that the C of G will always be higher than the axle, it is an inherent feature that the nose load produced will always become greater as the height of the tow hitch is lowered.
EU regulations set a limits for the height of a tow-ball on a car with a trailer attached of between 350 to 420mm. By selecting the lower limit for the height of the nose load gauge, the nose load will be maximised. The difference between the lower and upper hight limits is relatively small (70mm) and the change in nose load produced between the two height extremes will be quite small but always less than measured figure at the minimum height.
