Audi A6 Allroad BITDI tyre pressure
Sep 29, 2008
36
18,530
Any help would be appreciated i need tyre pressures for a Audi A6 Allroad 3.0 BITDI towing an Elddis Super Sirocco {2008}.....Thankyou.
9,469
Hi and welcome to the Forum.
The type of caravan doesn’t affect the tyre pressures. It’s car loading which includes the caravan noseweight applied to the towball. But aren't your tyre pressures detailed on a makers label generally on the B pillar. It’s normal to show light load, full load and a towing load. If towing load isn’t shown you would go with the full load figure. The only difference towing makes is that the load imposed on the towball ( noseweight) is considered to be a part of the cars total load. Do you have an Owners Manual for your car?
Reactions: JezzerB
4,738
If you can't find the pressures as Clives says, go up by 4 psi from cold pressures.
9,469
Whilst going up 4 psi from normal cold pressures will help, it’s quite an old rule of thumb. My car is 7 psi extra on the rears and 4 psi on the fronts for fully laden/towing. With the various types of tyres and aspect ratios the OP really needs to get the correct tyre pressures for fully laden and or towing. Otherwise he could be in for a big bill if uneven tyre wear should result from incorrect pressures.
4,449
The information is usually posted on the tyre pressure label fixed to the car. This normally covers partial load and full load setting. For towing use teh full load settings.
The same information is normally printed in the owners hand book.
Sep 29, 2008
36
18,530
Thanks for the replies - extra 7 PSI in rear and 4 PSI front was pretty spot on when i found it on sticker inside back passenger door - i was looking on drivers door and inside petrol cap.
4,738
Such an obvious place, just where you would expect it. 😮
