avondale age?
Mar 1, 2008
I am looking at buying a avondale leda the number on the windows is 60788160 is the age of the caravan in this code?
Thank you
L
spj
Apr 5, 2006
220
The year of manufacture is normally on a plate mounted by the door, if it is a modern van it will have a cris number on the windows, this should be a 17 digit number, if it has this then cris may be able to give you more info. Otherwise you could contact Avondale, as you don't have a problem with the van they may reply to you.
spj.
Aug 18, 2008
17
spj.
The CRIS number should be on the door and windows.
EG: SGAS000AV80001050
Breakdown: SGAS/SGAT = Single or Twin axle
: AV7/AV8 = 2007/2008
: 1050/2250 = Usualy there are about 20 prototypes per year with numbers starting 1001/1002/1003 etc. The production batches start around 1021. So 1050 will be at the beginning of the year batch 2250 will be near the end of the year batch.
The start of the new year batch usualy begins around July time.
Aug 18, 2008
17
18 Aug 2008 09:11 AM The CRIS number should be on the door and windows.
