Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
There are awning cleaners available that won't damage the fabric but you may need to waterproof it afterwards. I suspect there will be a mark left made by the mould staining. If so try a little lemon juice on the mark. Leave it for 20 mins and wash off. If this removes the mark or lightens it make up a solution of citric acid and use that sparingly. Citric acid is available from home brew shops and is the acid found in lemon juice. Treat it with respect and test a lttle bit of the fabric to make sure it does not damage. Keep it away from children and wear goggles.
