Awning light lens
Jul 6, 2008
Hi. I have a series 5 Bailey Pageant Moselle. Can Anyone tell me how to get the cover off the awning light to change a bulb?
The lamp is made by Ring.
Dec 27, 2006
451
Terrance
I dont know if it the same , I had a problem with the awning light on our Delta the bulb went and I couldnt find out how to get the cover of. On ours there is a downlighter for the caravan door and a semi circular light above for the awning. After much frustration I discovered there was 2 small plastic clips on the bottom of the housing which held the cover on. By gently pushing them with a screw driver and releasing them I was then able to carefully slide the housing upwards and gain access to the bulds. As I say I am not fammilair with the bailey's and cant guarentee they are the same,
Jul 6, 2008
Terrance
Thanks Del But the Bailey lamp is different with no access from the inside of the van.
Dec 27, 2006
451
Terrance
The Delta has no access from the inter, which was the problem and no visible screws on either the iside or outside. Have a good close look around the outside to see if there is any recess which could house the holding clips
Jul 6, 2008
Terrance
OK will do. Thanks
Dec 5, 2006
120
hi terence,
i had the same problem with my awning light on my swift and after a phone call to my dealer i was told to squeeze the lens hard and sure enough the lens popped off end of problem. it was a bit daunting as i thought i might break the lens but all was ok
