Awning pads
Mar 27, 2011
1,332
507
19,435
It's probably because I'm trying to post a picture using an iPad that its not working but seems that if you click on the blue highlighted link it will show the one picture which I'm sure will be plenty for the knowledgable people on here to identify it, fingers crossed anyway.
BP
Apr 7, 2008
4,909
Beehpee said:
I don't know if sprocket can help me out here by making the above 2 pictures visible, if you can the my question is does anyone know where I might get replacements for these awning pole pads from, the make of the awning is unknown so hoping someone might recognise them, that's if of course anyone ever gets to see the pictures.
BP
Have you thought about using some of these ?
646
Hi Those bracket pads look like the ones we had on a Eurovent porch some time ago,I suspect that most of the ones that fit to the second bead would work just as well, and I have found the ones in Sprockets photo are particularly good because of the tightening wheel mechanism.
Mar 27, 2011
1,332
507
19,435
Thanks for the replies peeps and for putting the pics in properly sprocket, I will take mine to nearby caravan spares shop and check if the different types look like thy will hold the poles in roughly same position and either get them there or order online, I like the look of the ones you've shown sprocket as I also lik the look of te screw tightener, thanks as always for the help.
BP
Nov 17, 2005
132
26
18,585
Beehpee,
If you get stuck, I have 6 Bradcot items sat on the garage shelf doing nothing.
Regards
Firkle
Jun 13, 2013
27
My porch awning has those types of pads while my full awning has the good old suction cups.
Don't forget that if you get stuck, you can replace the plastic type of pad with a suction cup....it's easy to do and a good emergency repair.
Always carry a spare!
