awning rail for building
Oct 3, 2022
26
7
535
Wifey wants me to put an awning rail on the gable end of the house so that we can use it to dry out after a wet take down but also be able to erect as a nice party tent. Our caravan awning rail is about 9 metres in length so I will need to acquire a rail of that length. Can anyone advise where I can get this and how do I bend it to shape?
2,352
Interesting question. Wish I knew the answer. 😀
My only thought is that Caravan dealers with awning showrooms or awning places like Renishaws or Towsure have their walls festooned with such things. Could give one of them a ring and see where they get them ( or even if they have one for sale) because I bet they don’t bend them themselves.
mel
D
Deleted member 23278
Do you need the full shape? Would a 4-4.5m straight length at 2.3-2.4m up the wall be sufficient?
26
7
535
Good question, that would certainly negate the need for bending, hopefully someone with experience of doing this will comment.
Dec 21, 2019
15
9
10,515
Hi '
not quite what you are proposing but I have a 3.0 m awning rail fastened to some shelves in my garage for use when awning taken down wet. Awning (size 900) pulled through and then supported by two pair of 7 step steps. Works very well to dry out awning I have tried erecting frame and this can be done but too much faff for a couple of days. Interesting aside purchased air awning and when delivered erected in garage on awning rail only to two of the tubes badly distorted and could not be fully inflated. Returned immediately as not fit for purpose.
241
47
18,585
I did what blackbird said, put a length of rail in my carport high enough to keep the base off the floor, ( my carport was blocked in by full size double doors) used to dry very quickly.
Trevor
Sam Vimes
2,791
2,269
12,935
Not a bad idea. (y)
For me and because the caravan is in the car port, I put the awning into the rails on the opposite side from the door and then tie the skirt up to some hooks in the wall. Gets a nice breeze through it and the hooks are high enough to get it off the ground.
