12V and Aeriel Socket fault.
We had a few days away this last week, just to check things out really? Our Cello TV wouldn't work, at least not on the usual aeriel socket? Used the other socket just around the corner and all was well. Bought a new socket and fitted it today, still not working, TV says No Signal? Is there a way of checking a Aeriel cable, continuity or something? I will strip the fitting off the cable but thought I'd ask for advice on here first? Thank you!
Check how many outputs have cables attached on the aerial amp and that they are all tight. If nothing wrong disconnect the cable marked for your non-functioning socket and make sure the centre core is still good - this assumes all connectors are screw-on F-type.
If you have a multimeter you can check continuity from amp connection to TV presentation on the centre core and the outer - although there will be a lot more copper in the outer so it is unlikely to fail.
The other check is to make sure the final cable or cables are not short circuit.
I'll get on that tomorrow, cheers Woodentop!
At that price might buy one that a bargain 👍
I stay in a old stone built cottage surrounded by hills, and got a quote for a external aerial to supply the bedroom. it was £240. Bought one of these and the picture i get is crystal clear, well worth £5, also take it with me in the van and works great. Being magnetic it can stick to motor home roofs with great success.
That reason i have brought it last time out the visionplus status 570 one minute working and the next nothing on signal Finder but now got some fuses so will check there .
Many people miss the fact that some (all?) of the VP range of aerial amps actually have a power switch on them. If one is present it is found in a small recess on the top surface of the case at the left end viewed from the front. The presence (or not!) of the (lit) blue led on the front panel of the amp is the giveaway. With the 570 the amp is in the internal amp case with the blue LED - which is unlike the earlier models which had the amp in the aerial case itself and the internal box is simply a power supply. (Earlier models had blue/purple writing on the aerial case, modern models like the 570 have red/orange writing.)
Note that if your van has a radio fitted in it the power for the aerial amp is often split off the radio supply. Ergo radio present and working the so should be the aerial amp. If your van does not have a radio then the aerial amp supply could come from anywhere.......
