Hi all need some advice from you seasoned caravaners last wk I set up on the seasonal pitch which all when well
so with all the resent rain I just pop over pop over (130 mile round trip} and check the van low and be hold their is a very slight leak coming from the awning rail were the rubber seal has been joined the gap is about 3mm. 1,should I reseal the join inside and out and check for crack along the rail on the outside and reseal if any.2,strip the rail off and a total reseal
I have check for damp with a meter and it was on service in jan all was spot on I am also thinking the tension on the roof pole might have something to do with it
