Hi I need some Help does any no the best way to keep the awning skirt tight and the quickest way to get my awning up as I amgoing to use part of it as an extra room with an inner tent.
Many thanks to all for your advice I will try the all.Hi
I've got one of the double-sided-awning-rail-attachment thingys - it came with my awning.
I also make sure that I've pegged either end of the skirt, making sure that it has good tension, which holds it in position better.
Mac
Thanks for the info you wouldnt have a picture you could post so that I can see how it works .David
There is a little Isabella gizmo that might do the trick. I think it's intended to be used in the awning top rail to stop porch awnings sliding sideways, but may solve your problem too. It's called SafeLock for Isabella Awnings. You can it from www.leisureshopdirect.com/caravan/outdoor/Isabella_Spare_Parts$$6.aspx
Ye gooooooood idea think I will try this one thanks.Hi David
Like many others, I too have had this same problem with the skirt. I cured it by making a small hole in the flat part of the bead where it is sewn onto the skirt material, (a paper punch is ideal), and then use an elastic bungee hook through the hole. Depending on which awning I am using I either put a peg in the ground to hook the other end of the bungee on to or hook it on to part of the chassis or corner steadies. It keeps sufficient tension in the skirt and is cheap and cheerful.
John M
