bailey carolina shower
the two taps in the van are very powerful but the shower head has only 4inches of of water pressure is this ok or do i have a problem given that the van has such a powerful pump i was hoping the shower would be as good as the taps
You have a problem
I would check the pipes for kinks and unscrew the shower head to see if its better without,thus ruling out blockage of the handset.
Our Oklahoma shower is very good so I would check the pipe runs for constriction.
Try all hot or all cold to rule out one or the other.
Good luck
You have a problem
Good luck
thanks i will try this
not going away till friday so will let you know when i get back thanks for checking
the power seems to come and go so its back to the dealer as bailey said there could be a blockage but i am not removing the box as i don t want to lose the warranty lee
