- Nov 11, 2009
- 25,627
- 9,386
- 50,935
Last time out I had a problem with the nearside rear fog light on the 2005 S5 Pageant. So today I went over to the van expecting to have to change a bulb. I took out the nearside Hella unit and checked the bulb and found no fault with its filament. So I decied to take all the bulbs out and clean the bulb terminals and also the terminals/connectors too. When I removed the complete Hella fitting I noticed that a group of white earth wires were all connected together but were not connected to the metal bulb holder. Looking at the earth terminals on the metal bulb holder there were no signs on any terminal that the earth wires had been connected. So I decided to connect the earth wires to the metal bulb holder and I replaced the assembly. I then checked out the offside unit which had been all cleaned up and greased last summer when a bulb blew. On the offside bulb holder the white group of earth wires were connected to the metal bulb holder.
I could not test the lights as the car I was using has no tow bar electrics. Is it normal to have only one of the two rear light assemblies positively connected to earth on the metal bulb holder, and is earthing both likely likely to cause any problems ?
