Baily Water problem
Mar 23, 2007
9
In 2004 we took possession of a new Bailey Ranger 470/4.
From day 1 we had trouble with a nasty taste and smell in the fresh water system.
Being new to caravanning at that time we assumed that it was something that we were doing wrong, or admitting to do at all.
We went back to our suppliers who were very helpful but baffled as to a cure for the problem. As a trial they fitted an inline filter in the system (as the Ranger does not have any filtration fitted) but this did little to help the situation.
We had already taken advice from more experienced caravaners and purified the system with 'Purachem and/or Milton, following the instructions to the letter and flushing the system afterwards.
It was usually fine for that evening but when opening the tap the next morning the smell and taste had returned.
In January this year we were fortunate enough to take possession of a new Bailey Pageant series 6 and found that we have the same problem again.
To prove that we were not getting paranoid about things we invited other people to smell and taste the water. The look on their faces gave us the answer.
My sister and her husband, who have been caravanning for 25 years are baffled by all this and swapped their Aquaroll with ours to at leaste to prove the Aquaroll was not at fault. They used our Aquaroll and had no problem.
After a few hours with my sisters Aqua roll connected the water was again tainted, so we came to the conclusion that the fault does not lie with the Aqua roll.
I contacted Bailey's to see if they could shed any light on the problem, or indeed suggest something else to try, but there answer was to replace the whole water system, including the hot water tank. This seemed to me, and my supplier to be a bit drastic for a brand new caravan.
Can you see anything that we are doing wrong, or suggest anything else we could try?
We are now having to use bottled water, which is proving not only expensive, but inconvenient and spoiling the enjoyment of our new van.
Feb 8, 2007
77
We took delivery of a brand new Bailey Senator just before Christmas and suffer exactly the same as you do regarding taste & smell of water. At first we put it down to the water supply at the site we were staying on, and use regularaly as we also store our van there, and just like you started using bottled water, until one visit where desperate for a drink filled the kettle direct from the site tap, and hey presto no smell or taste. I have come to the conclusion that they must put some sort of sterilizing agent in on the production line, rather than risk possible claim for food poisoning, just a thought. But if it does not improve with use I will be contacting the supplying dealer.
Berty...
Dec 16, 2003
2,893
Try washing out your water tank with a stong solution of water and Bicarbanate of Soda and then run a strong solution in the tank and in to the pipes and leave to stand for a few hours and then rinse out with fresh water.
Jeff, we always carry a 2ltr container, which we fill up direct from the cold water tank, for use with making tea or coffe plus water for the dog.Never had any bad taste or smell.Always fill the water containers and insert a milton tablet into each prior to our first trip, and run one of them through the pump to ensure that the taps are all okay.When the water containers are not in use I fix part of a old clean stocking over the filler entry to enable air to enter the containers and not spiders this has always keep them smelling sweet.
We had a inline filter in our last caravan, pain in the a... it was cost about
4,141
Hello Jeff
I can sympathise with your difficulty.
If the taste is like TCP (Antiseptic) then that indicates that the some plastic parts or pipework is leeching out its plasticiser into the water. The only solution is to replace the affect fittings and pipework.
If the taste is 'musty', then it probably points to the growth of algae, or mould somewhere in the system. If the infestation is mild, then a thorough cleaning of the pipes and fittings with proprietary cleaners may be successful, but if the infestation is severe, (the infestation has become embedded in the inner lining of the pipework) then again it means replacing pipes etc.
Cleaning agents you may consider:-
Diluted Hydrogen peroxide.
Chempro -SDP (used by the brewing industry- safe with water heaters)
Milton (or other baby bottle sterilises) Milton is basically a weak beach
With all the above, follow the suppliers instructions with regards to dilution and soak/exposure time.
Do not use normal domestic bleach - this is often modified to resist being washed away and it will attack the water heater or other metal parts in your system.
Have exactly the same problem with our 2007 Bailey Senator Arizona, smells tastes just like tcp/chlorine, so back to the supplying dealer who fobbed me off with a load of codswallop and basically told me it was my fault and I had contaminated the system (really it has been there from Day 1) so I phoned Bailey who immediately told me that the problem was with the pipes and they would have to be replaced under warranty back at the factory. Informed supplying dealer who almost called me a liar and wanted the name of the person who I had spoken to at Bailey, so I gave it to them and waited for a return call after they had spoken to them. Right sir the caravan will have to go back to Bailey at Bristol, but they cant fit it in until September, my reply not good enough, under the sales of goods act you are responsible for remedying the problem within " a reasonable amount of time" and sorry 4 months is not a reasonable amount of time, silence, well sir you could try phoning them, reply not my problem my contract is with yourselves not Bailey you phone them, well sir there after sales is cr*p and if you the consumer phone them it might hurry them along a bit!. Stalemate, hour latter phone call from dealer, we have spoken to Bailey again and they are now saying the information they gave you could be wrong, and before they rip the pipes out suggest that you clean the system with a priority cleaner to see if you can eradicate it. My reply was to tell them that it was there responsibility to carry out any remedial work to cure the problem, there reply if we clean it, which is a time consuming job and it cures the problem we will have to charge you for it as it is not covered under warranty, I will not tell you my reply other than to tell them I will be informing them by recorded letter that I will be rejecting the caravan as it is not fit for purpose. I have been informed by a very good source that the problem is at manufacture stage where they have used a cleaning agent in the pipes and have left it in to long before flushing it and it is now causing the pipes to leech in to the water???
The ongoing saga.......... Allan & Gill
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
DHDH
