- May 23, 2025
- 6
- 3
- 15
Hi all i have just brought a sprite alpine 2 2008. The battery is shot so i want to replace with lithium do i need to change the battery charger or could i just switch it off and charge with solar panel
It depends on the lithium battery. I have a kepworth 100ah that is a drop in replacement for lead acid. The voltage is managed by the BMS built into the battery. It's fine with the built in charger. I did change the solar controller to on that had a lithium option, as it allows a higher voltage for the bulk stage.Hi all i have just brought a sprite alpine 2 2008. The battery is shot so i want to replace with lithium do i need to change the battery charger or could i just switch it off and charge with solar panel
