Removing spare wheel from Alko chassis - any tips?
Sam Vimes
2,469
1,974
11,935
I'm just about to remove the spare wheel from my Elddis Xplore 304 for the first time, just to see whats involved. Its the one that's mounted under the chassis on a wire frame which needs to be dropped down.
I've thought of a few ways to do it but does anyone have any tips that might make my life easier?
8,894
Put the wheel up on a ramp to give more working space. If you can squirt some penetrating oil down the sliders. You may have to re grease when returning the wheel back under the van.
Reactions: Jcloughie
2,592
I just remove the safety pin, then the nut. Then pull out the frame with two hands, pull it out as far as possible and allow it to drop to the ground.
Awkward, but not difficult. (Very difficult if you have a flat tyre on that side.).
421
337
935
Elddis sometime use BPW chassis and the wheel carrier is a lot simpler than the Alko monstrosity and just swings down The OP mentioned a wire frame and this sounds like a BPW carrier, In either case if you can drop the front of the caravan down as far as it will go it will give you more space to work and clearance to drag the wheel out , also get some of those childrens playmats from screwfix , they are quite large and very pleasant to lie on whilst wrestling the wheel back onto the carriers and lifting it into position . Oh and don't do this with caravan parked near a kerb.
Sep 12, 2021
569
496
5,135
I have some of those ...... good suggestion to use them for this purpose.(y)
Oct 8, 2006
2,028
713
With either type of carrier I suggest wellying the runners with Waxoyl before putting them back. The solvent will evaporate and leave a covering of soft wax behind which stops rusting. You will never again have any issues removing the spare wheel and/or its carrier.
Sam Vimes
2,469
1,974
11,935
Thanks for the replies.
I'm sure I read somewhere that its best to jack up the caravan with it still attached to the car. I've looked through the caravan manual and it makes not mention of this. Any comments?
I've got plenty of stuff to lay on while doing it.
Thanks all
4,473
I have only had one puncture on my vans in 18 years. Fingers crossed.
The AlKo carrier is a pain to get the wheel out from , putting the jockey wheel as low as possible helps. I did notice that the AlKo carrier frame rubs on tyre side wall. After removing it several times to check the pressure. I got fed up and put the spare under our island bed, and removed the carrier.
I have the KoJack hydraulic scissor jack to lift the van as well as the Normal wind up one. When using those I leave the van attached to the car.
3,425
Thanks all
Yes, the caravan has a tendency to move once the weight has been taken off one side and may fall off thejack - got the t-shirt! With the caravan hitched to the car, it can't twist round.
Sep 23, 2023
1,288
546
1,435
Stops the caravan from rolling back if it's on an incline,try and make sure all the tools required are on hand readily available to save time once it's lifted and safely secured off the ground by stands on the axle to chassis plate(if it's an Alko there are four large bolts that clamp the axle to chassis) ...Good luck
Sam Vimes
2,469
1,974
11,935
Got the spare wheel out. Forced the retaining strap off and let gravity do the rest. Boy is it rusty.
I need to use it for a while as Alloy Wheel tyre is damaged. Rain stopped play so swapping over tomorow.
Thanks again
