Removing spare wheel from Alko chassis - any tips?
Sam Vimes
2,492
1,995
11,935
I'm just about to remove the spare wheel from my Elddis Xplore 304 for the first time, just to see whats involved. Its the one that's mounted under the chassis on a wire frame which needs to be dropped down.
I've thought of a few ways to do it but does anyone have any tips that might make my life easier?
8,938
Put the wheel up on a ramp to give more working space. If you can squirt some penetrating oil down the sliders. You may have to re grease when returning the wheel back under the van.
Reactions: Jcloughie
2,595
I just remove the safety pin, then the nut. Then pull out the frame with two hands, pull it out as far as possible and allow it to drop to the ground.
Awkward, but not difficult. (Very difficult if you have a flat tyre on that side.).
427
342
935
Elddis sometime use BPW chassis and the wheel carrier is a lot simpler than the Alko monstrosity and just swings down The OP mentioned a wire frame and this sounds like a BPW carrier, In either case if you can drop the front of the caravan down as far as it will go it will give you more space to work and clearance to drag the wheel out , also get some of those childrens playmats from screwfix , they are quite large and very pleasant to lie on whilst wrestling the wheel back onto the carriers and lifting it into position . Oh and don't do this with caravan parked near a kerb.
Sep 12, 2021
570
497
5,135
I have some of those ...... good suggestion to use them for this purpose.(y)
Oct 8, 2006
2,032
715
With either type of carrier I suggest wellying the runners with Waxoyl before putting them back. The solvent will evaporate and leave a covering of soft wax behind which stops rusting. You will never again have any issues removing the spare wheel and/or its carrier.
Sam Vimes
2,492
1,995
11,935
Thanks for the replies.
I'm sure I read somewhere that its best to jack up the caravan with it still attached to the car. I've looked through the caravan manual and it makes not mention of this. Any comments?
I've got plenty of stuff to lay on while doing it.
Thanks all
4,486
I have only had one puncture on my vans in 18 years. Fingers crossed.
The AlKo carrier is a pain to get the wheel out from , putting the jockey wheel as low as possible helps. I did notice that the AlKo carrier frame rubs on tyre side wall. After removing it several times to check the pressure. I got fed up and put the spare under our island bed, and removed the carrier.
I have the KoJack hydraulic scissor jack to lift the van as well as the Normal wind up one. When using those I leave the van attached to the car.
3,451
Thanks all
Yes, the caravan has a tendency to move once the weight has been taken off one side and may fall off thejack - got the t-shirt! With the caravan hitched to the car, it can't twist round.
Sep 23, 2023
1,304
555
1,435
Stops the caravan from rolling back if it's on an incline,try and make sure all the tools required are on hand readily available to save time once it's lifted and safely secured off the ground by stands on the axle to chassis plate(if it's an Alko there are four large bolts that clamp the axle to chassis) ...Good luck
Sam Vimes
2,492
1,995
11,935
Got the spare wheel out. Forced the retaining strap off and let gravity do the rest. Boy is it rusty.
I need to use it for a while as Alloy Wheel tyre is damaged. Rain stopped play so swapping over tomorow.
Thanks again
427
342
935
Like Hutch I didn't like the Alko carrier its a real pain , so I removed it and keep the spare either in the van ( in an IKEA Dimpa bag strapped to the floor or in the car) and underneath the caravan when on site.I also have fitted the Kojack system (bottle jack ) and the retaining plates which lock the jack onto the chassis to help stop it twisting.
Sam Vimes
2,492
1,995
11,935
Finished the job this morning.
To remove the wheel from the caravan and fit the spare took about 15mins or so. Jacking up with the trolley jack was a little awkward as it has to go under the caravan, lengthwise, and not sticking out the side. So, pumping it up took time because I could only do short strokes at a distance. Fortunately you don't have to jack it up as high as a car wheel.
We've decided to carry the spare wheel - when its back as a spare - in the caravan when towing and in the awning, under the caravan or in the back of the car when on site. There's no room inside the caravan to have it permanently in there.
I was going to remove the actual carrier but you can't just unhook it, so when the next trip is over in a couple of weeks and the annual service has been done and I tuck it up for the winter, I'll go underneath and unbolt it.
Got as much rust off the spare wheel as possible and was then going to spray it black but couldn't find the black spray paint. I had some Black Sandtex - no idea why because we've never used it - so I painted that on. Its better than rust :)
8,938
Does Sandtex still have 15 year guarantee. If so it will outlast the caravan.
Apr 23, 2024
427
342
935
@Sam Vimes , well Done . the Alko spare carrier is held on to the chassis with Split pins , mine were so corroded , that I ended up grinding them off with a diamond angle grinder.Also gives you another 13kg of payload.
To help you store and move it without getting your hands dirty store it in one of these bags https://www.ikea.com/gb/en/p/dimpa-storage-bag-transparent-10056770/ . A member of a forum recommended it to me and It's very robust and keeps the tyre clean as well as other things it may touch.
5,227
A bit late in . My AWS engineer removes the spare each service and lubricates the moving parts. I've had to use it once , no problem. But with a puncture on the NS you must use a Milenco type leveller or boards for height.
Without regular use it will seize.
More lube😉
4,486
That bag looks really strong, Might get two, one for the wheel, easier to lift. And one for my Cadac, as that bag has fallen apart.
4,486
If you do remove the AlKo wheel carrier, remember to remove the rubber grommets for future selling or refitting.
Sam Vimes
2,492
1,995
11,935
Good thought...... When it stops raining I'll give the whole of the caravan a coat :)
I think my carrier must be different. A bit hard to describe - I should have taken pictures. Its just some bent iron bars if that makes sense.
The end you release is just a toggle catch, then the whole lot falls down. The other end is the the rods bent down and passed through some holes in a bracket screwed to the underside of the caravan. The bend is too much to be able to pull it out as the ground gets in the way.
Apr 23, 2024
427
342
935
@Sam Vimes , thats a BPW wheel carrier , a lot lighter and IMO more practical than the Alko versions.I have come across a few , and a lot easier to access and replace the spare wheel
5,153
Our 2018 caravan had a ALKO chassis but with the BPW drop down carrier. Made life a lot easier for us.
May 15, 2023
143
129
1,635
I don't think I have ever seen a good word written about the Alko slide wheel carrier! The problems get compounded because without use things rust and seize up
When I got our van a couple of years ago I changed all the tyres including the spare, so had the fight with the wheel carrier, but at least with the luxury of being at home and not under pressure of having to do it roadside. The following post describes what I did to improve things:
https://forums.practicalcaravan.com/threads/alko-spare-wheel-carrier.65910/
Pulling the carrier out every 3 months and re-applying dry PTFE certainly has improved things.
8,938
That was quite a package of maintenance that you carried out. I’m afraid I took the other option to carry the spare in the caravan and to send the carrier to the HRC skips.
