Battery Check and maintenance
Mar 3, 2024
93
21
585
We are fairly new to caravan life (had caravan just one year). Our Swift Sprite Major 4EB 2025 model has been on a seasonal pitch with hookup for the first year, but from March it will be in storage when not out touring.
We were looking to do some rallies and trips where there is no hookup during the coming year. In view of this, the last 2 times we were at the van, I disconnected the mains charging function to see how long the battery lasted. Both times, the panel on the caravan was beeping and saying low battery on the 2nd morning after arriving, so it lasted less than 48 hours before claiming to need recharge. Fridge, TV are running off mains, so the battery is only being used for the caravan heating fan, lights, internet router.
To be fair, we did have the heating on most of the day from the Saturday afternoon and most of the day Sunday and lights on all evening from about 4.30pm.
The van has a solar panel but our pitch is under a tree and it generates pretty much zero in the winter.
Does this indicate that the battery needs checking if it is only lasting less than 2 days?
We went to a couple of 4 day festivals last summer and no issue, but this could be because the solar panel was topping it up in summer.
The van is going in for its first service in 2 weeks, so I will also ask them to check the battery at that point. Wife is talking about booking a 9 day rally on a non electric pitch in July, so we will need to be able to cover 9 days potentially somehow.
9,597
Are your lights LED and in July lights and heating wil be far less than you have experienced. What size is your solar panel as this will significantly affect your ability to maintain battery life. Also what size battery do you have? Your four day summer experience was a positive one, and if your lifestyle stays constant then 9 days should be feasible. But what you don’t say is after the four days what voltage was your battery showing.
93
21
585
Are your lights LED and in July lights and heating wil be far less than you have experienced. What size is your solar panel as this will significantly affect your ability to maintain battery life. Also what size battery do you have? Your four day summer experience was a positive one, and if your lifestyle stays constant then 9 years should be feasible. But what you don’t say is after the four days what voltage was your battery showing.
I’ll get a photo tomorrow morning of the battery. I don’t know if the lights are LED - they are the factory fit lights as we had the caravan from new - 2025 model Swift Sprite. I’ll ask the dealer. I know that it was the more expensive one of the ones the dealer suggested as we said we would be going to festivals with no hookup.
I didn’t note the voltage after the 4 day summer experience.
I can tell you now that after about 29 hours since we disconnected the charger in the van, the voltage on the van panel is 11.6V “Fair”. this is with the living area lights on and the heating on (but the fan does not seem to be running at this moment).
I do remember noting when we were at the festival last year, that the solar panel was generating a heck of a lot more power than when we are on our normal pitch, which as I said is under some trees. It was obviously some months ago and I didn’t note the exact voltages, but I seem to recall that the battery was only just starting to say “Fair” after 4.5 days of camping, and from memory I think the first 2 days were sunny but the last 2 days were very cloudy.
Edit: Acccording to the brochure the lights are LED.
661
526
1,135
2 days off grid in winter seems pretty good to me I have 260W of solar panels and even in summer have to be careful on usage ( big variability on solar output during our british summer), having said that I do run a 60W cool box ( with a low voltage/temperature cut-out controller so the battery doesn't get flattened). To test your battery you need to put it under load , most batteries are rated at the C20 discharge rate so for a 100A. battery = 1 hour at 100A ( not achievable) is the C1 rate, the C20 is 100 A.hr/20hr = 5A is the rate which would flatten the battery in 20 hours. If you can switch on stuff in the caravan and monitor the current to get about a 5A drain by removing the battery fuse and inserting this monitor ( see first photo) and time how long the battery lasts. I have a much faster way but not as accurate I load the battery with about a 1000A and watch the voltage using one of these ( see second photo) if it stays about 11.4-12 V for 30 seconds then its pretty OK , if it quickly falls away ( 10-15 seconds) to 10V or less then its on its way out. My get out to battery anxiety whilst off grid is :- I have bought a 280A.hr Li-PO4 battery ( and a 3kW inverter) and added the necessary wiring so I either use the internal battery or the lithium(which lives in the awning) to power the caravan .
Reactions: Javert
2,795
This is not comparing like for like. You now have the heater fan on for much of the time as well as the lights. Last summer the fan would not be needed, and less lighting required.
I don’t think that 48 hours of fan and lights is unreasonable.
93
21
585
Thanks - yes I am aware that it's not the same as in the summer, but I was curious as to whether about 48 hours is unreasonably low, as when I researched this a bit I saw some posts implying that this could be within the expected range, whereas other posts were from people who claimed their battery lasted 4.5 days in the middle of winter in a snowstorm with the heating running all the time, lights on and TV running several hours a day. Of course maybe they had extra batteries or something.
2,362
From your post I am assuming that you were on trialling off grid on your seasonal pitch on which your caravan had been standing, not connected to hook up whilst you were away?
Hence the only thing keeping the battery topped up prior to arrival was the solar panel?
Had you ensued that the Sargent black switch on the box under the front seat was in the off position when you were absent from the van, hence shutting off all 12v power when you were not there?
What was the battery voltage when you arrived at the van?
The reason I ask is if the Sargent switch was not off, you may have already had a partially depleted battery before you started as sunshine ( especially this winter) has been poor.
Good luck
93
21
585
Good luck
No the van was left connected and the charger left on during the time I was away from the van (4 days), so the battery would have been as fully charged as it can get using just the caravan charger when we arrived - I turned off the charger as soon as we arrived to test the endurance.
We don't normally turn off the inverter when not at the van as it shuts off the fridge and since we are visiting the van most weekends, we leave the fridge running (as do most other people on our site). From what I recall, when I tested shutting off that black switch it also shut off all of the 240V power even though the cable was still connected.
When our van goes into storage from March onwards, the Sargent switch will be turned off when we are not at the van. Unfortunately the only spot available is right next to the warehouse where they store caravans inside, at the SSW side of the warehouse, so I'm guessing the van will only get solar for half the day at best. However they said we can use a nearby power point to top up the battery every few weeks if we need to.
In reality we are planning to use the van at least once a month this year which is the main reason why we did not renew our seasonal pitch. Hopefully a trip to Europe will be on the cards later in the year.
Reactions: Mel and otherclive
Mar 3, 2024
93
21
585
This is the Exide battery that has been fitted from new (just coming up to 1 year).
Apr 23, 2024
661
526
1,135
The black power switch on the Sargent EDU ( EC 400 or above) doesn't turn off the mains it merely shuts down the 12V systems including the internal microprocessor , but the 12V EDU system will still draw some power from the battery , The mains systems will still be live if on electric hook up. Also the solar panel is connected to the battery and will try and keep it topped up.
Mar 3, 2024
93
21
585
Are you sure because when I tested it some months ago, when I switched off that black power switch it shut off the fridge. I can’t remember whether it shut off the microwave or not. Maybe it’s more that the fridge shuts down because it requires 12V power for the control cirtuits?
Otherwise I will test it again next weekend.
2,795
On our seasonal pitch we are away for the 3 winter months. Back in March. I think that most leave their vans on EHU. I have unplugged and turned off power in the van as much as I can, just the alarm I think. My hope is that the 100 watt solar will keep it topped up. I think it will.
1,555
1,001
1,935
He should know, he's a caravan engineer 😉
Reactions: Javert
4,210
1,931
I concur with others, your 48 hours under the loading you stated is impressive, and this aligns well with the battery you have being both a quality product and still in good health.
You simply can't draw any constructive data from what you achieved in the winter to what you will likely achieve in the more summer conditions, say late April through till early October.
Unless your van has a compressor fridge I hope is not doing more than taking a miniscule amount of energy to power its electronics, its cooling energy , massively greater coming from gas. To achieve lengthy off EHU summer camping, without having a large solar array really does need the fridge to run on gas.
Then there is the TV another high energy user if run for long during the evenings. The longer day light and the good social atmosphere typical of rallying are both likely to significantly reduce the "need" to use the TV that much. If not then your will power will be needed to discipline its evenings usage. Daytime use of the TV tends to be less critical as then the solar can provide much if not all its needs and probably gives post use time to recover from the solar.
As said the heating and lighting are inherently minimised during the summer, the former can be very energy demanding, the lighting, now typically LED becomes way less so than back in the halogen bulb era. If you have any halogen lighting leave if off or change it to LED.
Then we come to another very significant winter summer feature,
the potential solar energy gathered.
The winter sun angle is low and solar panels deployed flat on van roofs suffer greatly from this, not getting any direct sunlight hitting them anything close to "normal" angle, square on. They can only glean from reflected sunlight off the clouds, and not even this if under tree cover etc. Add to that the sun is higher for much longer in the summer, so the array both gathers a higher charging current, and for very much longer.
Winter vs Summer solar daily performance of flat mounted solar panels is like chalk & cheese, vastly different favouring summer use.
With a bit of self discipline, at least initially finding your way I have little doubt if you continue to look after your battery you will be fine doing lengthy off grid rallies, many of us do just that.
I could go for as long as I wanted off grid rallying through the summer with only a free standing 85Watt solar panel providing our electrical needs, frequently 28 days a time that only limited by a need to come home for more pills. Agreed the free standing panel gives a better yield but then it normally would have recharged the battery [90Ah Exide] by noon, and spent long hour being laid nearly flat so did not require retracking.
Last season I acquired an EcoFlo 1kWh Power pack and 200Watt solar panel, gone is the need for any restrain and in comes the use of a mains slow cooker, bike recharging and use of a mains kettle, but its just an indulgence far from actual needed; nice though.
Go for it and discover the whole rewarding camping world there is rallying.
93
21
585
That’s a good battery that should do the job. Why not next time out go on EHU pitch but don’t hook up and see how solar panel copes with your usage. If the battery voltage starts to drop then you have EHU to fall back on for the rest of your trip.
With this type of battery and the standard charger fitted on the Swift Sprite, I am not sure whether it makes sense to occasionally remove the battery and charge it up manually?
I’ve seen a lot of articles about how you should do this, but I am not clear whether this was more relating to older caravans - I think that the charger that’s built into the new caravans is already a smart charger - at least, I can see that it varies the current dynamically during the charge cycle, and it says in the manual that it’s fine to leave it on charge continuously.
On the other hand, there are lots of articles suggesting that the battery will not charge up to the real 100% capacity until you connect it to a manual charger (or your car)? Is this actually true for these modern batteries and chargers?
9,597
I was only suggesting that you pitch with EHU but do not connect the electric supply and rely on your battery during lighter days to see how long it will last before you need EHU to be connected. That way your trip won’t be negatively affected by the battery running down if the solar panel cannot replenish it.
Modern caravans do tend to have smart chargers so there may be no requirement to remove a battery especially as you have a solar panel too. The biggest risk to your battery is depleting its charge by letting its voltage drop.
This CMHC bulletin gives a good explanation of battery care.
4,210
1,931
With such a modern van from a reputable builder I really would expect it has a smart technology charging system. If I faced checking I would make some quite revealing tests if the documentation or web checks on the actual charger's spec does not make what it has evident.
I would measure the voltages on the battery's post during other than the "float" phase of recharging .
Importantly this needs to be done at night or with the Solar system's fuse pulled so not to throw the read values. [ The solar I confidently expect will be "smart", so we need that to be out of picture whilst testing the mains charger]
If I saw voltages of 14.4 to 14.7 volts then the charger is functioning as a smart charger.
If it really just sat at 13.8 or a bit down throughout the phases then its pretty sure its a relatively dumb charger.
The measurements must be on the battery itself not the van's power outlets etc as with smart charging systems the van's system is likely to be further controlled to not expose any in van delicate kit to the over voltages reached during smart charging.
661
526
1,135
@Javert Yes I'm sure , and yes you are correct the fridge requires 12V from the control system and yes the shutdown switch will remove power to all 12V systems( apart from the alarm system and the solar panel charging the battery) .The microwave is totally 230V and will work, whilst on hook up , also the charger isn't disconnected from the battery.
Mar 3, 2024
93
21
585
Thanks for the clarification - just to check what you mean by the last bit in bold, are you saying that if the green switch (battery charger) is on, but the black switch is off, the battery will still charge if on hook up?
Apr 23, 2024
661
526
1,135
YEP, there is a direct connection from the chargers output , via fuse( No1 )to the battery in the back of the EDU . You can quickly test this by measuring the battery voltage across its terminals with no hook up and then again with it on hook up with the shutdown button in the OFF position. you should see a marked difference.
Out of curiosity I was wondering why Sargent specify such a high drain current ( about 100mA) even in the shutdown mode so I connected up a couple of different charger /PSU modules I've got lying about in my workshop, to a voltage source on their outputs to measure the current going back into the chargers 12V control circuitry.
As I raised the voltage past about 13.7-13.8V the current into the chargers' input rose dramatically up 100mA , which may explain why the EDU systems take so much ( relatively). If the battery settles back to 12.6V then the current would significantly reduce down to about 1mA
