Battery not charging
Oct 15, 2023
6
15
I have a lunar quasar 462 2008. The battery charger has stopped working. Can I connect an intelligent charger plugged into the mains socket on the van and connect it to the battery so bypassing the faulty charger?
2,108
Yes - that's exactly what I did with our previous caravan - although on that I was able to switch the onboard power supply off.
2,108
Thank you for your reply. How do you mean "I was able to switch the onboard power supply off."
Some onboard power supplies, also known as onboard chargers, have a switch to enable them to be switched off - but many don't have such a switch - in our case it wasn't broken but a smart charger looked after the battery better.
Reactions: ProfJohnL
