I need your help (again)
I have a sited swift Conqueror 640. I thought I would enjoy the sunny weekend in my caravan however!!!
I filled the on board water tank using the external Whale pump (opened hot tap etc) then switch it on to the internal pump but nothing happened. The pump is working (I can hear it) but no water..Possible air lock, I tried for three hours and still no water. Tried adjusting the pressure switch, this will not switch off!
I checked the voltage on my battery and it was down to 8 volts could this be a possible cause? I switched on the on board charger (light illuminated) left it over night and STILL the battery volts were in the red. I thought the battery was dead...but on returning home I put it on charge and its up to 12.8 volts!!!. Possible on board charger fault.. I checked the in line fuse, this was ok( little melted, but working, checked with multi meter).
Does anybody know the location of the charger and where I can buy one (if this is the problem).
For your information I use the site's mains electricity
Sorry for the length of entry but i'm at my wits end
