battery
On most modern caravans, the answer is yes. You mat require to operate a switch or two. Should tell you in your manual.
What tye and age of 'van do you have?
hi David Our van is a 1994 swift 490 se. We have now bought a new battery but not tried it yet. When ever Whenever we hook up on site the battery always goes flat
thanks
laura
Check your control panel - there should be a switch for the battery to charge, which says 'car' and 'van'. When you hook up on site, make sure the battery charger button is switched to 'van' and only on 'car' when you are towing (that will charge the battery while you are driving). If you don't have these options, you may have to buy a battery charger (Halfords do a great fully automatic battery charger, suitable for slow charging caravan leisure batteries - important not to damage them by charging too fast), and take it out periodically to charge it. You should never let it fully discharge, or it will damage the battery and severely shorten its life. If in doubt, check with a caravan dealer which sells Swifts.
Good luck
Lois
Hi Lois,
pardon my ignorance, but when charging on site, should the rocker switch not be in the middle setting, and only on van when on a non elec site, or car when getting power from the car .
thanks, anthony
Hi Lois,
thanks, anthony
Just realized why my battery never charged, was misinformed when buying the van, but been put right by my local dealer.
(I feel such a plonker)
