bbq point
does anyone know whether it is ok to feedgas INTO system via this? Itenters the gas system on the canniste side of regulator.
937
No it is NOT ok to feed gas into the caravan system through the BBQ point
I've been doing this on my last two vans. I can't see any way that this is dangerous.
Probably the same sort of stupid arguments that made us use bulkhead mounted regulators.
Nov 20, 2006
191
ALL NEW 2004 CARAVANS ARE NOW SUPPLIED WITH
THE GAS REGULATORS FITTED AND THE CORRECT
PIGTAIL HOSE MUST BE USED, IN ACCORDANCE
WITH EN 1949. NEVER USE A REGULATOR OTHER
THAN THE ONE FITTED TO YOUR CARAVAN
FITTING OF EXTRA T-PIECES FOR ADDITIONAL
INLETS IS NOT ALLOWED BECAUSE GAS BOTTLE
REGULATORS DO CONFORM TO THESE NEW
REGULATIONS. THE CARAVAN REGULATORS HAVE A
WORKING PRESSURE OF 30mbar AND THE OLD
STYLE REGULATORS ARE 28mbar AND 37mbar.
UNDER NO CIRCUMSTANCES CAN YOU CONNECT A
GAS BOTTLE TO THE BBQ POINT FOR A GAS INLET.
BOTH OF THE ABOVE PRACTICES ARE AGAINST THE
REGULATIONS AND ARE EXTREMELY DANGEROUS
although I wear glasses I can still manage lower case
