Bessacar E350
Jun 27, 2011
Is it possible for me to fit a new fresh water pump into my 1998 Bessacar E350 I have been told at a local dealer that it is a long job having to undo the water tank staps undo all the pipe work to fit a new pump I don't this can be right why should a van coverter make it so dificult. can some one help on this job ?
Jan 23, 2011
236
Hi scubawabbit
Sounds like your dealer is not interested in the work.
Could you just drop in a submersible Pump via the tank filler ?
Even fit the 12v plug into an existing 12v supply socket if your need is urgent.
Jan 23, 2011
236
Hi scubawabbit
Jun 27, 2011
Hi The tank filler is mounted on the side of my motor home I'll have to have a look underneath to see if I can get acces to where the filler pipe goes into the fresh water tank.
