No our AWS caravan engineer brought the new ones and took the old ones and he knew someone wanted them .Did you manage to get Flogas to exchange your cylinders or just get new contracts, What sort of initial cost were involved?
The problem started when the pull out slide separating the top and bottom compartments needed lubricating nearly every three to four days, then the flush push button packed up, replacement unit housing the button was £126.00. Our son found a replacement button on eBay , a 5pack for £2.95. And soldered it in.Was that a magor change or just a we bit cosmetic?
Do you take them home each time? Does the site have refills?No our AWS caravan engineer brought the new ones and took the old ones and he knew someone wanted them .
You can get gaslights delivered.Do you take them home each time? Does the site have refills?
Really does make me wonder just what development testing is carried out on caravans. A neat and cheap solution by you though.Foam pipe insulation is useful for a few applications. Our previous van had the central washroom with the quadrant shower. The sliding doors were forever jumping off track while travelling, inserting short pieces of insulation between the doors and shower tray stopped this happening
I used a TP Link router with a 4G data SIM. The aerial is a 4G mounted on top of a piece of plastic conduit that attached to the caravan with a clamp-on bracket (the base stays attached to the caravan with an adhesive pad). The router cables terminate in the battery box and the aerial cables plug into them via a socket.What did you use for the wireless router and removable ariel?
