For many years i have leveled (side to side)the van reversing my twin axel van over the ramps, hopping in and out of the landrover to check the spirit level. Can anyone suggest a easier way?
Stephen
Stephen
I'll stick to hardstandings and level pitches then,Happy L,-your suggested method of levelling won't work. When you lower your van onto the ramps/blocks, the van will settle on its suspension, and still be out of level. The only way to make this work is firstly to measure from the wheel arch to a fixed point on the wheel. Then jack the van to level. If the wheel is still in contact with the ground, take the same measurement again, and deduct one from the other to calculate the correct packing. You will have to continue jacking to get this in place, but the van should settle to the desired height! If the wheel is clear of the ground, you will have to add a packing thickness for this as well....
Oldfogey-brilliant! This sort of gadget makes caravanning interesting even when not away. Does the phrase "its something your dad made" sound familiar? I suspect we've all got some favourite little gadget this...slight concern over SWMBO leaning forward to check gadget, then reeling back covered in ink as outfit lurches....
Why don't you just roll a marble down the centre of the van?The things I do ;O)
Hang string and weight to inside centre of middle window. Put a sticker on outside of window at the bottom dead centre. They will line up when the van is level.
Sorry about spelling on pics but I ain't doing this again ;O)
