bike carrier
Hi
I want to get a bike carrier that goes on the A frame, i've seen one from Fiamma available from Towsure. Has anyone used/got one of these, and how safe and secure are the bikes.
Dawn
It very much depends upon which caravan you have.
If it is a Continental one with an extended "A" frame they are fine.
If your caravan is a UK built one, then check that the "A" frame is long enough to accommodate the carrier and that you can afford an additional 35-50kg weight on the front.
Hi Dawn I have a Caravan XL A bike carrier ive had it for 4 yrs no problem as yet fitted it myself, but like rod says it depends on your A frame,I have a burstner with an extended A frame. I would definately recomend the carrier it adjusts so you can get in the gas locker even with the bikes fitted.
Ian
