Has anyone any experience of fitting an aftermarket blown air heating kit or an add-on kit.
Also looking for advice on fitting blinds and fly screens.
Any help cheers.
I fitted the Carver junior blown air kit and also an early Fanmaster
You fix the ducting to a knock out on the back of the carver fire and with the Junior you run the ducting to the blower which requires 12 supply and then you drill 2in approx holes in bed bases etc where you want the outlet to be and run the ducting to them .The Fanmaster is similar but you have a mains heater element as well.
The heat from the Fanmaster is more controllable.Hope that helps
