blown air heating
Jul 21, 2009
6
hi just wonder if any one can help,heating is making all the right noises but blowing cold air. one second hot the next it was cold. hope to hear from someone soon
cheers pip
44
19,185
It would help to say who's make of blown air heating you have? or if you don't know that, perhaps just the year of the van will do
44
19,185
It would be a 99 which gives two possible Fanmaster's?! the mk1 which will probably be on the back of a Carver 3600 fire and use a wall mounted control switch, or, the mk2 4000/5500 which uses a slide switch control on the top shelf of the gas fire itself.
With the mk1, the likely problem is it's overheated and tripped out, have a look here for where to press to reset it;
http://www.arcsystems.biz/Pictures/fanmasterreset2.jpg
If it's the mk2 then the first thing I would suspect is the mains 'kettle plug' has come loose, this plugs sideways into the bottom of the control box, you will find this over the back of the fire, top right behind the gas control knob, make sure it's fully pushed in
If it helps, the position of this kettle plug is the same as for the reset for the mk1 but on the opposite side of the fire
If not the plug then the slide switch control causes most other problems
Jul 21, 2009
6
thanks gary for all your help, it is a mk1 ,on the carver3600. i,ll pop down to the van on the weekend and give it a try,ps any idea why it would overheat,sorry for being a pain, once again many many many thanks pip
