Blown heating
Nov 8, 2014
We're pretty new to caravanning and just cannot seem to get the heating to operate how we think it should do. We have tried both the gas and electric ways of operation and in simple terms it doesn't seem to get that hot when everything is operating on the maximum. The actual force of the heating isn't that great either. When operation is by using the gas I'm not sure it gets hot at all. There maybe some simple thing were not doing correctly. Can any one help. The system is a trauma and the caravan is a Steling eccles amethyst.
3,832
Are you getting warm air out of the vent nozzles? Presumably you have the thermostat turned up to the level you want?
Check all the blown-air pipe runs to ensure that not of the joints have come apart - check any underfloor runs of pipework for security, could be very advantageous to add insulation to the outside runs.
Nov 8, 2014
Hi ,
All of the internal fentanyl are open. I don't think there is any problems with the pipes as heat comes out but the further away from the heater it becomes very faint.
3,832
There may be a lever on the fan unit, at the back of the heater, which apportions the flow between it's two outlets.
Nov 8, 2014
Hi,
I found the lever and I have moved it about to alter the flow. This has been successful but it's just not that warm or powerful.
3,832
Check each of the electric power settings in turn, give the outlets a little time to stabilise - if you get an increase in output going from 0.5kw to 1kw but no increase going from 1kw to 2kw, then the 2kw relay is fubar - but I know the man who can fix that.
3,832
Sprintermotocross said:
Thanks for the advice. If I need any help do you know anyone near southampton?
A contributor here, gary, knows all there is to know about Carver heaters and more than most on Truna and other makes http://www.arcsystems.biz/ he often does mail order repairs ONCE it's been fully diagnosed.
937
If you look here: http://www.approvedworkshops.co.uk/search/
You will find a mobile engineer close to you who can look at your heater and fix it if there is something wrong with it.
46
19,185
Thanks Roger and nice to see you posting more often :)
So, my first question is how old is the van?, reason is the gas fire is generally very reliable and should roast you!, so perhaps through extensive lack of use the fires valve is now stuck and not letting the main burner light?
In this case you are only getting the heat from a feebly pilot light and not the 3kw of the main burner, if then on lighting pilot and letting go of the control knob, you cannot instantly hear the roar of the main burner lighting, then the fire needs servicing.
As for the 'Ultraheat' electric heating sides problems, what follows should help lead to the reason/s?!!........
The Ultraheat’s wattage settings are there so you can make use of low amperage hookups, ideally 500W for 6A, 1000W for 10A and 2000W for 16A hookups, their not there to adjust the temperature of the van.
(You could of course use 6A for 1000W and 10A for 2000W, however you will be very limited on what else you can use at the same time, remembering to switch down or off while boiling a kettle can help get the best use out of low amperage hook up’s)
The Ultraheat is thermostatically controlled, therefore the wattage used will simply mean the fire is heating for shorter or longer periods. Where the problems arise then is if the temperature control is not working correctly, this is often due to the heat from the elements directly affecting the sensor itself,. The sensor is within the control switch, depending then where the switch is installed, this means the heat of the fire can bring the temperature sensor up to that set on the dial directly and the elements switch off, you and the van are still cold but the sensors toasty and takes forever to cool before switching the fire back on!!
A few common bad places to find the switch are in the side of the wardrobe above the fire or in a bed box where blown air pipes run, or perhaps even behind where the TV sits so the heat from the back of the TV or it’s transformer warms it up!
Due to this and particularly overnight, it's become something of an urban myth to set it at 500w or 1000w, this or that number on the dial and fan speed setting. In truth what's happening is the available heat is not capable of reaching the set temperature so never switches off, it's a useful work around but not how it should work.
The real solution is to fit a ‘remote’ temperature sensor and attach it to the gas fires sensor, if a remote is already fitted, it to will usually react better if moved to this location.
Setting the fan on manual speed means the fan runs at this speed regardless of the amount of heat being produced, I would suggest manual fan is only for use without heat for cooling in summer, if infact it has a use?!
Setting the fan to ‘A’utomatic allows the heat produced to control the fan speed ‘up’ to the speed set on the dial, you can then, keep this set maximum low and therefore quiet, overnight perhaps?
Automatic means the fan will run slowly initially and speed up as the air passing through gets warmer, doing it this way allows heat and fan to be switched on together and doing away with waiting xx minutes as often suggested.
I would suggest as a start and during the day, the wattage selected is as high as the hook up allows and then fan speed set to maximum on Automatic.
This provides the maximum heat if required and the fans speed will respond to change in temperature, ie, fast when heat cycle is on and slow when heat is off.
After that you can fine tune to suit your own needs
Other heating problems concern the control board, the elements are switched on and off by relays and the contacts burn out, particularly the two 1kw relays. If this happens you may think you have it set to 2kw but only one element is working, finally perhaps leaving you with just 500w working when both 2kw and1kw settings no longer work.
(Note, relays will still be heard to ‘click’ but unless you have heat, their not working)
The 12v for control also comes from this board and the transformer sometimes packs up, apart from no heat, you will lose the green light in the switch if this happens
Also if no heat is forth coming, there are two safety thermostats which switch the power to the elements off if things to hot. The lower one set at 125C will automatically reset after cooling, the higher 175C stat will hold itself off until power is removed, you must then switch off the mains supply to the heater and then it will reset automatically after a few minutes when power can be restored.
The lower 125C stat can fail when hot but well before it’s set temperature, this will mimic a relay fault and the heating switch off before the set temperature on the dial is reached. However checking the stat for continuity when cold will show a perfect reading, only way to be sure is to change it.
Note; if either thermostat is faulty it won't be able to reset, if faulty it can sometimes show itself by the vans main RCD tripping, but not always.
Finally, the mains isolation ‘fused switch spur’ can loose it’s connection through the built in fuse, the fuse is not the problem but the fuse holders connections that seem to be the problem
The main control switch itself seems generally reliable but the odd one does fail, the fan control switch when set to ‘A’ should make a positive connection and not switch on and off at the merest touch.
The numbers on the dial represent roughly 4degs and 9 is 32degs or thereabouts, this in theory makes 6 or 7 'normal' but it's what feels comfortable that matters not the number.
Other problems not caused by the heater itself are long runs of un-insulated blown air pipe running outside under the floor, insulating this will improve matters considerable.
The kitchen cabinet is often fitted over a wheel arch, much larger than required holes for clearance over the arch are used, the resultant heavy draught coming from behind the fridge can be eliminated by simply sealing the gap on the fridge side of the centre
cupboard.
Any draughts coming from the front of the fridge should also be eliminated.
Fix bed models very often have large floor vents under the bed, these are only useful in storgage and are easily block with a towel while the vans in use,
It’s also known for blown air outlets to blow toward the fire and this will upset the temperature control, adjusting these to blow away or even blocking off completely can actually improve overall heating.
Everything installed and working as it should, there is no good reason why the electric heating should not work very well and keep an even temperature to suit your needs.
However, it must be remembered the van needs to be warmed through thoroughly, (not just the air), before the heating is turned down. While the vans cold it will constantly drag heat from the air and this in turn needs constant topping up or the van will always feel ‘draughty’. It's most useful then while particularly cold to use gas as well for the first couple of hours, also, if the heating is off during the day to turn it back on at the first sign of a chill.
4,462
We don't know how old the caravan is, or how much its been used, but one thing that often happens in addition to all the other good points already made, is the heater and the fan impeller can become very blocked with detritus, (Dog hair, dust etc). This dramatically reduced the airflow through the fan, so its a sensible suggestion to check the fan once a years and if necessary clean it.
Be very careful and take your time and avoid bending any of the fanblades, use a vacuum cleaner and a pointed object like a cocktail stick to systematically weed out any dust lodged between the fan blades. One or more of the blades may have a metal clip on them, this is to balance the fan so avoid moving them.
Another possible failure can be the motor brushes. Depending on the model used the brushes may be replaceable.
If in doubt refer the work to a competent person.
