Hi guys. Just brought a 2002 BMW 320d e46. It's a 2lt diesel salon with a manual gearbox. It's got a towbar fitted and just wondered if it any good for towing. With got a 2 berth caravan and I'm aware of the 80% rule.
BMW 320d Data can be found hereWoodlandsCamper said:What's the kerb weight of the car?
What's the MTPLM of the caravan?
What's the max tow weight of the car?
What's the power rating of the car?
Edit - 85% is not a 'rule' only a 'suggestion'.
seth1 said:Way hay here we go again,hymm and verse about to be preached.
Woodentop said:I would suggest that the OP contacts a BMW dealer. One of the 320 series is not rated to tow although I cannot remember which one. The fact that it has a towbar fitted means nothing.
ProfJohnL said:Woodentop said:I would suggest that the OP contacts a BMW dealer. One of the 320 series is not rated to tow although I cannot remember which one. The fact that it has a towbar fitted means nothing.
This is good advice as I pointed out data bases can be wrong. However if you have the car, then a quick look at the weight plate and see if it lists the GTW as being bigger than the GVW. THe difference between the two is the guaranteed towing limit, though some manufacturers did list a higher max towed load, provide the car was not fully loaded. I don't know if BMW ever used this method.
