BPW chassis and IDC stabilizer
Sep 14, 2015
66
Hi folks ... Not posted for a bit as everything going ok with nearly 18 months of touring . But !!! just had an issue with IDC , BPW's version of ATC ... Its worked fine and then all of a sudden, no self test and Green led ..... Service engineer was coming for annual service asked him to have a look , He said never seen this fault quoted approx. £900 for new unit but it might be wiring fault and to leave it with him ,three days later ,I thought I'd check where all the wiring went . Really quite simple underneath the sensor wires disappearing to middle of van. Led wires and White and Orange main feed and earth into unit . Main feed plug had traces of Verdigris from it so whipped it out lo and behold electrically dirty ,all cleaned up trailer plug refitted in Tiguan (13pin ) and Whir whir self test and led green and steady . Fixed in 10 mins . Question any one know exactly where white and the orange cables go in the transformer box (couldn't see with out stripping it out but found the wires ) And any one power the plug up from the socket I assume its pin 9 and 3 to give permanent live from car to the unit
Aug 23, 2009
3,167
Absolutely no idea about the tech stuff BUT what an absolute rip off of a service chap thinking that a new unit fitted would be as high as £900. I really can't imagine it being that much. At least it's sorted now.
Mar 13, 2007
1,750
well one could say that was a good DIY job. :whistle: :whistle: :whistle: :whistle: but the engineer would have to quote on the worse case scenario. so it figures.
had the EPS [electric power steering] play up on the car. took it in as it's hidden under gummings somewhere up front. the guy at the garage said if the units gone there £700 or a new one or £200 used. I must have the car so told him to go ahead. but it turned out to be a loose connector. so only cost £40 as it took him an hour just to get to it.
OP scenario could have been similar.
