Brake Rod Support Bracket
Dec 14, 2012
Hi everyone, the brake rod support bracket has come loose on my Swift Challenger. The screws have pulled out. Can anyone tell me what size screws I need?
The van is only 2 years old, but the dealer is some way away, so would like to repair myself.
Thank you.
2,770
Would these be the screws which fix to the underside of the floor? If so, you could try over size (thicker) screws into the same holes. Or cavity fixings, or glue a 6mm ply plate to cover the area and screw into that for improved purchase.
4,738
The brake rod support is well known to come off, John idea of a wooden plate is a very good idea
5,461
While it is good that you can repair it, remember that when you do the warranty in that area may become invalid.
The way I look at it, is that there may be a hidden reason why the screws have pulled out which may require further repair at a later stage.
4,738
The hidden reason being, the screws are too short and probably not thick enough to hold the rod support in place when bouncing around on the road.
Reactions: Jcloughie
Oct 21, 2020
413
260
10,935
Mine fell off too, can't remember what size screws I used but I did use some no10 stainless self tappers with a dab of gorilla glue on the thread.
Kev
Reactions: Hutch and Jcloughie
