Hi Julie,
Does each leg adjust seperatly. If so Twist the lower outer section of the leg anti clock wise, this should let off the pressure on the clamping olive inside the leg and you should be able the adjust the leg hight. If this does not work try clockwise. In both cases the legs should be on the floor and not the table top.
Rob
